Discuss Kitchen Timber Floor Prep work in the British & UK Tiling Forum area at TilersForums.com.
GlennM
hi there
I am about to start my first floor tiling job on timber and have been reading through the site for hints and tips. The only floors i have done up to now are concrete.
From advice I have been given, i had planned to do the following.
- Kitchen is all floorboards, so I am going to put down plywood.
- screwed down every 4 inches (100 mm) in grids
- plywood of 12mm depth (afraid to go any higher to avoid creating a big gap/step at doorways)
A lot of the posts mention using primer on the back of the plywood and edges. It might be a stupid question but why am I doing this? Are the screws not going to make it solid enough? or is there another reason?
- as for adhesive and grout. I am planning on using flexi adhesive and flexi grout. Is this the correct way to go?
Is there anything else important that I am missing?
Any advice is appreciated.
Glenn
david campbell
Thanks guys.
So if it is just a kitchen and their won't be much moisture, can I skip this bit? Do I have to prime the back of the ply thats touching the floorboards?
Div - i actually don't know anything about backerboards. Would they be a better way to go than ply?
Thanks again
they would be better and the minimum height for ply would be 12mm whereas backerboards can be used in 6mm
peckers
Thanks guys.
Thanks again
I would always prime the ply no matter its only in the kitchen, and it doesn't take much time or expense, if you were to nock over the bucket of water while mopping the floor then you are giving the ply added protection in case it got damp.
If you want to decrease the level of the floor which is raised by the ply then use the hardi backerboard,
you will find info on it here on this site, sorry dont know where as i am still finding my way round ere..:smilewinkgrin:
grumpygrouter
Is the primer not simply to prevent too much suction from the timber - to stop it sucking the moisture out of the addy before it has time to set properly.
Whether you prime the tiling face of the ply is dependant on the adhesive manufacturers instructions. BAL say not to prime, but Ardex do (with 7001 adhesive) for instance.
Reply to Kitchen Timber Floor Prep work in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
