rob, the only way to get rid of water on the knee is a pair of drain pipe trousers...
ok that was bad, but couldnt resist it...doug, ffs put them away, i was having breakfast ..lol
rob, i suffered with this for years, it was the worst time of my life, ive had so much fluid on my knee i could hardly walk, it was so bad i had to have an opperation 2 years ago to remove the bursa sacs that produce the fluid, since then touch wood it hasnt come back..
if i was you i would go see the doc, he may drain it, some docs will, some will say you have to have it done in hospital, trouble is they can sometimes drain it and with in an hour it can be back again, what you really need is a steriod injection in the knee, this will settle it down with in a couple of days, and should last 2/3 months, be warned this hurts like hell even worse when he misses the spot and the needle hits the bone...:yikes:
failing that they will tell you to rest it, trouble is they have never been self employed and dont understand you have to keep working, i used to put a tight bandage on mine , one of those sporty type jobs you can get from the chemist, and soldier on, and rest as much as poss, just work and rest.......it will go, but it could be days, weeks, months......good luck mate ,ive been there....and know what its like...
