Dougs Third Go
Has anyone tiled onto these? and if so what addy did you use? Contractor says that they've used these in the past and found that a normal spf addy struggled to set onto them so he's keen to use a rapid set. I phoned kudos and they said that a normal spf is fine. I don't fancy using a rapid set on walls in summer so I was thinking of maybe using a S2 adhesive such as tilemaster ultimate. Any thoughts appreciated folks
