Discuss labour price in the UK Tiling Forum area at TilersForums.com.
dave l and l
got asked to quote for job today from company i have worked for a few times
job is 50 mile away approx traveling is one hour. however this is all the info i have been given
labour only rate to install johnstons primatics 200 X 100mm tiles 130m2
labour only rate to install external tile bead to exposed corners to pipeboxing 139m
thats all the info i have been given, could any of you work a quote out from that
bugs183
Those Prismatics really slow you down on fixing times as they are so small. I did some showers the other day in them and took much longer than i had thought it would.
I also found that fixing them with a 6mm trowel which you would expect to use was fairly useless with these. I swapped to a chunkier 8mm and the worked out much flatter and bedded in nicely.
You'll use twice the grout of an average job too.
I'd look at how many meters it will take you to do in a day for each tiler work the day rate out and add adhesive, grout and trims.
Then divide that by the meterage and you'll be surprised what these could actually cost fellas cost to fix per m2.
Find out how big the boxings are, this could play a major part in the quote.
Reply to labour price in the UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
Hello All, I posted back in September and you were all very helpful with your advice on what to...
Dumbo
Hi everyone I've done several trades across construction, and the thing I struggle most with is...
12K
I've 2 bathrooms to price in an old peoples home that's 3.5m sq witj 2.5m ceiling height using...
I
labour price
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
