Discuss large 60x30cm porcelain tiles on suspended plywood with backerboard? in the UK Tiling Forum area at TilersForums.com.
Mirjam
Dear Tilers Forum,
On our ground floor - for various reasons, which I don't explain here, we want to put down:
- existing concrete
- vapour and radon barrier
- insulation boards and 70x25mm wood battens
- 18mm hardwood plywood
- 6mm hardiebacker
then the question: CAN WE USE LARGE PORCELAIN TILES (30X60X9mm) ????
or are smaller tiles preferable? (30x30x9mm) for example?
if so, why?
Thanks,
Alexander and Mirjam.
Mirjam
2 reasons:
- we want floor insulation, since it is the ground floor
- there is bitumen based aspestos glue on the concrete which we prefer not to scrape off, but rather cover it up as we have been told by aspestos experts. because of the bitumen we cannot glue anything onto it (otherwise we could use strong insulation boards instead of the ply construction.
why dont you just tile to he concrete ?
Reply to large 60x30cm porcelain tiles on suspended plywood with backerboard? in the UK Tiling Forum area at TilersForums.com
Hi everyone, I'm having the majority of the ground floor of my house tiled (35m²) and I'm not...
Hi All, I urgently need some advice and not sure where to turn. We are having some major...
6K
Rookery
Hi, We have been in our house a few years but noticed as soon as we moved in that the tiles...
8K
Rosewood
11K
Rizzle from the Portizzle
U
About a year ago, I had 64 sqm porcelain tiles installed on top of a concrete slab, forming a...
12K
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
