Discuss large ceramics in the British & UK Tiling Forum area at TilersForums.com.
charlie1
Hi all,
I'm doing a job next week with large ceramics so i will be using rapid set cement adhesive with large format floor trowel. The problem i've had in the past is i find working with cement adhesive quite slow as you only have 20 to 30 mins work time with each batch you mix, when you consider all the meassuring and cutting that needs doing i dont seem to get much done before it starts to go off.
What method do you guys use when tiling with rapid set?
Thanks for all the advice.
F
Fekin
Hi all,
If rapid set is umm... setting too quickly for you, then don't use rapid set, lol
I have never used rapid set, so other than don't use it if it goes off too quickly for you theres nothing else I can suggest.
DHTiling
hi woody mate..use something like bal spf...it sets in 16hrs and has a very long bucket life....great for large format tiles......rapidset is good if you want same day installations but not always practical if you cant tile fast enough to use it up before it sets...so use spf and it will last ages...good luck........dave..
DHTiling
any single part flexi will do woody mate...CTF3 is only a slightly modified adhesive..where as bal single part flexi is a highly modified adhesive and can be used in more situations like tiling to floors as well as walls.....as far as i know topps will be able to get bal spf but might have to order it in...I get mine from CTD is there not a branch near to you.... Ceramic Tile Distributors
....dave..
I
IvegotsTILE
If I were you I'd do all the full tiles first with your first few batches,then mark and cut all the tiles you need to,mark the tiles in sequence so you know where they go then mix up a batch and just skim the back of the cut tiles and put them in place.
If your trying to just do row after row and do all the cuts as you go along you will find the mix going off cause your taking time to mark tiles and go away and cut them.
grumpygrouter
Hi Woody, I have the same problem as you as my speed is not there yet. BAL single part flexy has a bucket time of 5 hrs, so has Ardex X7G. Plenty of time normally to use it all up. I still wasted some though on my last job as there ware parts that required holes drilling and the like and with the temprature being quite high, it went off a bit quicker.
Got a big-ish job coming up next week on a floor and will be using it for that.
Grumpy
Grumpy
Reply to large ceramics in the British & UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi All - I am searching for Todagres Aral Beige Pulido tile (large format - 32"x32"/ 120cm x...
large ceramics
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
