Discuss large format tile adhesive in the UK Tiling Forum area at TilersForums.com.
milesd
Hi,
I need to fix 600 x 300 x 9.5 mm ceramic tiles to plasterboard that has had the skim removed to expose the plasterboard (also in some areas the plasterboard has been plastered over).
So if I understand this thread correctly I need to:
  1. Prime the plasterboard with Everbuild SBR (does it go on neat?)
  2. Use Mapei Keraquick tile adhesive
For the shower area that I intend to tank will I need to apply the SBR on top and then adhere tiles or do I just tile over the tanking finish?
Thanks.
p.s. What area would 5L of SBR bond cover? What surface area would a 5kg bag of Mapei Keraquick cover?
aph257
Hi,
  1. Prime the plasterboard with Everbuild SBR (does it go on neat?) 1pt SBR to 3 water
For the shower area that I intend to tank will I need to apply the SBR on top and then adhere tiles or do I just tile over the tanking finish? yes, SBR then Tank then tile.
Thanks.
p.s. What area would 5L of SBR bond cover? more than enough for a house. What surface area would a 5kg bag of Mapei Keraquick cover?
5kg will cover approx 2M2. 20kg bag about 8m2. You will need to use a thin bed /solid bed trowel.
Reply to large format tile adhesive in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
I'm having a nightmare trying to establish product info from distributors. For example...
