Discuss Large format tiling in the UK Tiling Forum area at TilersForums.com.
Brad
Hi all.....
Could someone please point me in the direction of a good thread on trowels to use for large format wall tiling.
I am also looking for some experienced advice about the correct way to tile large format wall tiles. Particularly porcelain. I have been tiling for a reasonable time now, but have little experience fixing large format. I am unsure on the correct trowel size to use on say a 600x600....also how much addy to use?? For example, after trowelling the wall, do I back butter the tile, or is it good enough to just skim the back of the tile??
Thank you.
charlie1
Usually opt for a 12mm trowel and back skim. Maybe 10mm on very flat walls.
Same for me mate!
There a lot more to tiling with large format than picking the right trowel! It's sooo different,from tilind with smaller tiles! I love it when customers often coment when I'm tiling with large formatctiles "that will take you no time, because of the size of them!" I timed myself recently Doug a 900x300, from troweling, backskimming to making sure perfect and inserting spacers, it took me 7 minutes ( I am v fussy though!)
Re trowel size for 600sq I would be using 12 square notch and back skimming!
Reply to Large format tiling in the UK Tiling Forum area at TilersForums.com
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Tilers Forums on FB
