Discuss Large format tiling in the Canada Tile Advice area at TilersForums.com.
Hi,
I have 40m2 of extension joined onto about 30m2 of the existing house that I want to tile with somthing like 60x60 tiles.
Both parts have underfloor heating and the extension was screeded with sand and cement about 4 weeks ago now. The whole floor is level over the 12meters but wouldn't say its flat. It has some ups and downs of +/- 5mm so 10mm difference in places.
So my plan was to lay Ditra matting over the whole lot. I will probably use a Weber adhesive.
My question is about the actual tiling really. As it's a bit higher in places I was going to start tiling at one of the higher areas if the floor and then use a laser level and/or a string line to keep the whole lot flat as well as a good tile levelling/clip system.
Does this sound about right? Any help or guidance would be useful. I can't use a self leveller as the screed is only a month old..
Reply to Large format tiling in the Canada Tile Advice area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Uk
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
Business Name
Prop dev 1
Large format tiling
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
