U
Unregistered
Hi, I had my shower installed by a local (but very reputable) builder some 18 months ago and tiled with the above tiles. Initially there was an issue with the tile adhesive not setting and slight mvoement in the tiles. He came out, agreed they were no good and stripped the tiles completely, cleaned them off and re-applied them with a two-part adhesive and they set with 24-48 hours. Since then all hunky dory until a few days ago.
I noticed one of the grout joints has cracked (along the height of two of the tiles). When I look closer two of the tiles on one side of the grout seem to be slightly (1mm) proud of the two on the other - ie I can very slightly see the exposed cracked edge of the grout rather than just the face. If I put pressure on the protruding tiles I can push them back - please bear in mind the movement is no more than 'very slight'. I then thought I would check further and worked my way around the tiles tapping them with my fingers and although most tiles have a solid clunk to them similar to tapping a breeze block wall (which is what is behind) there is an area of about 1 sq m from the ceiling/corner that has a hollow sound to it in places almost like there is a slight gap behind the tiles.
I have not approached the builder yet (he will love me but I'm sure he would rectify it) but am curious to know if I am being petty or is there a likelihood the tiles could get worse and heaven forbid fall?
