ah666
Looking for a bit of advice
I have a for my sins designed a tiled pattern where a section 600 x 600 within the main tiles (which are 300 x600 rectified and 10mm thick), is formed of 4 sheets of Mosaic tiles (300x300)
I want to ensure that these Mosaics are flat and look good
I have done some Mosaics before but only in a thin strip around 100mm wide and to do this I followed some instructions on this site and made a wooden adhesive spreader to get the adhesive to the correct depth before installing the tiles, this worked well
Should I follow the same process for a large area or is there a better way. I also thought about mixing the adhesive slightly thicker so that I don’t manage to push the mosaics into the adhesive to deep
Any advice appreciated
AH666
AH666
