U
Unregistered
Getting tilers to my remote property is like finding a needle in that haystack.... should I tackle the 25 sq. M kitchen floor myself?
Laying riven slate 300mm x 300mm tiles on a concrete floor that is nearly flat - and that is one bit that worries me.... there is a slight ridge, around 5mm, where a wall once stood....and I want a flat floor!
Do I lay something like 10cm thick tile adhesive from one end of the room and , using a spirt level just work my way back, eventually over the ridge hoping that will be even?
Cutting slate tiles with a tile cutter - is that the way?
Which adhesive & type should I use?
Addy
Addy
