Laying 12mm Travertine Externally
Hi All,
So i'm looking for some advice on laying travertine DIY. Here is the situation:
  • 38 sqm area
  • Substrate is a 125mm concrete slab freshly laid and is 3 weeks cured
  • The substrate has a suitable fall for water run off
  • Tiles purchase - Linen coloured 12mm Travertine 406x406 bought form Beaumont Tiles
My question is (and im finding it so hard to find an answer).......
1) What adhesive should I use? Ive been recommended Ardex but both Ardex and Beaumont Tiles and a few websites are telling me to use different Ardex product?? X18/X68/X77 etc. Im worried if i used the wrong one then the tile will stain on the surface. Im hearing that travertine is NON-Moisture sensitive?
2) Im assuming waterproofing is an absolute must? Any recommendations? I don't want so complicated waterproofing process. Just something simply and easy to apply.....maybe Ardex WPM130?
Other than that I think i'm pretty clear on everything else like the 1) pre sealer i need 2) Penetrating sealer and Grout.
Cheers and thanks for everyone help!
Gavin in Brisbane
The main issue is your concrete slab , it’s nowhere near cured enough to tile at that thickness.
1mm per day for the first 40mm and then 2mm per day for the rest and that’s based on internal location .
gavinfielding,
Dave,
gavinfielding,
Dave,
