Discuss Laying down 25mm WBP plywood ready for tiling in the UK Tiling Forum area at TilersForums.com.
aled
Hi,
I am replacing my bathroom floor with 25mm wbp plywood. I will be using 3 sheets of plywood and was wondering how best to 'butt' them together. I have seen on various forums that I need to leave about a 2mm gap between the sheets. Do I need to fill in the gap with a flexible adhesive and then tape over it with something similar to plasterboard tape? What would you recommend?
Thanks in advance
Scott
Seal the edges an BACK of the ply but not necessarily the face of the ply. That will depend on your adhesive manufactureres instructions.
The screw heads will be fine, the moisture content in the adhesive is negligible and isnt enough to cause damage. Nor IMO is it enough to swell the ply at the edges? if it was then it would be enough to swell the surface of the ply. The edges and back are sealed to prevent moisture ingress but from other sources.
Reply to Laying down 25mm WBP plywood ready for tiling in the UK Tiling Forum area at TilersForums.com
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
