tintin
Hello I'm new around here
I'm also a novice so I'm hoping you experts will be able to provide me with a few tips/point me in the right direction.
Want to put up a small quantity of glass mosiac tiles as a cooker splashback. These are in sheets of 30cm (12" square.
I started with a small test area using BAL Blue Star adhesive which was a bit of a disaster. I called BAL and they recommended I use their Mosiac fix which I believe has better grab.
However from my test area I have two other problems
Must get this job completed ASAP so any advice/practical tips will be very welcome
Thanks in advance
Tintin
- When you lay each square, how do you prevent too much adhesive coming through the hesian
- Secondly and more importantly how to you maintain the space beteen individual mosiacs.
Thanks in advance
Tintin
