Discuss Laying limestone over T2 reflecta insulation board in the Australia Tiling Forum area at TilersForums.com.
jonnyc
Looking at a job wher the spec is 45-50mm screed laid over existing concrete base .
two large areas .
the reflecta panel which is 13mm thick has an aluminium face on which t2reflecta -p-fix primer is applied before any flex adhesive can apparently be used to fix 20 mm limestone on top .
the reflecta panel is glued to the screed with a raychem adhesive.
The t2 red cable Is electric and clips in to the grooves in the insulation board.
has anyone used this system before ?
bit similar to the polypipe over lay except using electric heat wire rather than water pipes as in poly pipe system.
with polypipe the only guaranteed method I know is to glue and screw 6 mm hardie backer or similar on top of insulation.
any info or experience of fixing on this raychem system appreciated
Reply to Laying limestone over T2 reflecta insulation board in the Australia Tiling Forum area at TilersForums.com
23K
Deleted member 57709
Dear Experts! Here's a homeowner looking for advice about a home renovation project. It's a...
GoneGuy
I've been quoted for 2 different methods of fitting an UFH system by the electrician. Both will...
doddsie
Hi All, Got an interesting one in a couple of weeks, existing kitchen is tiled and new tiling...
anyone fixed tiles or stone on top of this system. pipes are set in insulation boards that are...
6K
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
