revo
I have resently added a new extention to the back of my property and in doing so taken out most of the original back wall. The original part of the property has a suspended timber floor. I replaced some of the joists and added some blocks for support as well as some noggins. I then screwed the old 6" wide soft wood floor boards back down. But not before adding a wet underfloor heating system. I have been told that I should add another layer of ply boards on top of the floor boards, but the heating manufactures have told me that I shoud not have more than 25mm of timber floor. This being that timber is a good insulator and the heating will not get through more than the 25mm. The old boards I have reused are 22mm, they're not tongue and groove and some have small gaps between. I've added a 3.5mm layer of ply, that I've stapled down and gone mad with the staples. In the new extention I've put in the underfloor heating system and poured concrete. The two floors are now level with each other. The concrete has been down now for over 3 months and the heating went on a week ago. No signs of any cracking or movement. The timber floor seems quite solid. I want to lay terracota tiles throughout. Do I need to use a membrane like dura mat? Is there anything else I should consider doing before laying the tiles? There is also a very slight fall in the floor, could I attempt to level this out as I bed the tiles down or just go with it?
