Discuss Laying travertine on electric underfloor heating. in the Canada Tile Advice area at TilersForums.com.
Hi all, I can't seem to find a thread with the info I need so hopefully someone can help 🤞
I have a 25 sqm extension which I have just built for a customer which he now wants tiled with honed and filled travertine tiles 600x300 from Topps tiles layed in brick bond format,
I have had a tiler friend of mine come and quote the job, then he calls me a few days later and says he is a little worried about the tiles cracking,
At the moment it's a concrete screed with latex on top, and insulated cement boards combed with tile Addy onto the screed with the recommended expansion gaps around the outside edge,
Electric underfloor heating will be fitted next week and latexed ready to tile!
Can the tiles be laid with a flexible Addy straight into the screed without cracking?
Albert
1,253
Gateshead NE8, UK
Thanks for the reply, very helpful!
I heard you need the antifracture membrane but when I checked the bal sitework guidence it doesn't specify you need to use it.
Are there any other travertines which are better? Thanks.
[automerge]1568836303[/automerge]
My customer is pretty set on using travertine 🤦🏻‍♂️
A lot of porcelain lookalikes out there
Boggs
1,118
Uk
What about using Ditra heat, 2 birds, one stone....
Sean Kelly
1,068
Ruislip
You definitely need an uncoupling membrane with natural stone.
Topps travertine is not good quality. You will need double the quantity as every box will have cracked and damaged tiles. It will take the tiler half a day just to check the tiles for damage etc.
I was on a job a few years ago where i had to go back to Topps 3 times to exchange boxes of bad travertine.
Reply to Laying travertine on electric underfloor heating. in the Canada Tile Advice area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
Tilers Forums on FB
