Guest viewing is limited
Discuss laying wall tiles or floor tiles first in the Best Floor Tiles area at TilersForums.com.
Deleted member 9966
if you're not happy with the edges after they've been cut hasher, can you speak to your tiler and explain this? can you tell him what kind of finished edge you're looking for?
I'm sure there are lots of photographic examples on this forum and across the internet where you can show your tiler the difference between finishes.
also, what kind of cutting device is your tiler using?
Spud
I nearly always tile my floors in first then do the walls ,several reasons for this but mainly personal choice imo joints line through more acurately ,allows the plumbers and other trades an accurate finished floor height which is helpful when setting out borders etc if there is furniture and fittings in the room, biggest draw back is working on your finished floor but this is easliy sorted with a sheet of cordex or a dust sheet
Reply to laying wall tiles or floor tiles first in the Best Floor Tiles area at TilersForums.com
How would you go about tiling a floor and or wall that's massively out of plumb ? When things...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Wall & Floor Tiler Queensland Australia Tile Right About the role Seeking a Wall & Floor Tiler...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
