Guest viewing is limited
Discuss Leaking wet room drain in the UK Tiling Forum area at TilersForums.com.
Della
This is my first post so hello who ever is out there:smilewinkgrin: we have a wet room drain that appears to have come adrift .When the hair catching thing (trap)gets full of gunk ,the water instead of overflowing over the wet room floor is leaking out underneath as it seems there is a gap as if it hasn't been screwed together correctly. The whole bottom section of the drain doesn't seem to be attached to the part tiled in to the floor.
if we cut a hole in the ceiling under the drain would we be able to reattach it ?
Any ideas anyone ?
Reply to Leaking wet room drain in the UK Tiling Forum area at TilersForums.com
  • Sticky
We've had a wet room installed upstairs using the Impey wet room system (see attached). The...
hi there, i was not sure if i should put this in find a tiler section as i was more hoping the...
Unused Account 1
U
Hi folks, I am having a downstairs small bathroom completely renovated. There will be a new...
H
Any help or suggestions would be greatly appreciated. We are renovating our house and a year ago...
16K
mache
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
