Guest viewing is limited
Discuss leaking wetroom in the UK Tiling Forum area at TilersForums.com.
L
leakybathroom
I would be really grateful for some helpful advice - I have a wetroom tiled with porcelain tiles that has leaked. My bulider has talked about covering the floor with good quality lino as the best option or alternatively to re-tile with a polythene or visqueen sheet as a waterproof membrane. Not sure what to go for.... any thoughts? I want a solution that will give me piece of mind against further leaks.
Deleted member 9966
just moved in to the house. The wetroom is an en-suite in a loft conversion undertaken by the previous owners 2 years ago
do you have any details of the tradesmen who did this work for the previous owners? for the wetroom to fail within 2 years, it's my opinion that the whole installation needs to be reviewed. Ideally, the tradesmen that installed it to start with should have given some kind of guarantee over the work.
unless you know what materials were used and how the whole thing was put together to start with, you're going to have problems repairing the wetroom.
Reply to leaking wetroom in the UK Tiling Forum area at TilersForums.com
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
  • Sticky
leaking wetroom
