Discuss Level up an entire ground floor in the Canada Tile Advice area at TilersForums.com.
Son wants wood-effect tiles all the way from the front door to the back. Concrete on all floors - but levels vary falling away to the back.
He's asked to insulate the floors with insulation board throughout - probably 10mm.
Given that we have enough height for the thickness - how best to level up and set out? I am fine on both these jobs, but have only ever done a room at a time before. So - hallway, knocked though living / dining room / kitchen and utility all the same.
Thanks in advance.
Dumbo
Thanks in advance.
Find the highest point . Drill the floor and put a screw in 3mm above floor level , use this as your datum point . Then repeat this process but setting each screw to the height of the first screw . Then level floor to the height of the screws .
Reply to Level up an entire ground floor in the Canada Tile Advice area at TilersForums.com
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Wales
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
