David Bingham
Looking for some advice ,
Upstairs bathroom is chipboard floor .
I planned to hardiebacker then tile but the floor is out 20mm one way and 12mm the other way .
Floor needs to be level as there’s a traditional rad that has legs and 2 units going in and you will notice it .
What’s the best way of Levelling out?
My first thought was to rip floor up , level and ply it but the airing cupboard wall sits between two joists and the other joist is under neath the hot water cylinder so wouldn’t be able to get under it to support the wall .
Would thick bed adhesive do it? And if so Is it a case of using he thick bed adhesive trowel on the back of tile and on the floor to build it up?
They are glazed porcelain 450 x450 floor tiles
