Discuss Levelling out a aqual panel wall for tiling large format in the Canada Tile Advice area at TilersForums.com.
rupert
Hi All,
I have boarded a wall with aqua panel, dot and dabbed and then plugged and screwed to give a mechanical fixing.
Despite best efforts in ensuring all boards were level and no lippage between the joints, one of the boards seems to have pulled in too much along the top . I’ve put a straight edge over it which extends from the level board to the ceiling.
The top of the board needs coming out. There is about a 5mm gap at the top reducing down gradually to the levelled panel lower down.
I can’t take this board off now as its been dob and dabbed. What is the best way to bring out the level?
Can I use rapid set to build up the gap?
Thanks.
rupert
ailill
Ireland
Hi Rupert,
I am very interested in using the mentioned boards.
Could you, please, post some pictures showing the way you fix them?
What do you glue them to the wall with & what screws and plugs do you use?
What is the frequency of dobs and dabs?
When do you put the screws and plugs?
Thanks a mil
Peter
Reply to Levelling out a aqual panel wall for tiling large format in the Canada Tile Advice area at TilersForums.com
I am planning to tile bathroom with large porcelain tiles 1200x600 over water-resistant backer...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.1%
    Votes: 38 28.8%
    Votes: 16 12.1%
    Votes: 32 24.2%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.4%
    Votes: 18 13.6%
    Votes: 15 11.4%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
