Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Light weight adhesives in the Tiling Standards area at TilersForums.com.
L
LM
Magix , I can't my head around it . If it expands when wet does it shrink when it's dry ,
Interested to know how many litres it makes when mixed compared to standard ,
Well Jerry there are brands of adhesive out there that aren’t available easily for me and I’m keen to hear the views across the board. I’m wondering if they’re any good with LFT on floors etc or if there’s been many failures if any for example.
F
Flintstone
It's funny Lee I was going to start a light weight adhesive thread myself to ask a similar question.
I've used magix on several occasions and it's plus points are it wets out easier then the standard equivalent, setaflex.
It doesn't seem as sticky and seems to dry out quicker if that makes sense to you.
I've not used any others really, except that lightweight from TM but only once.
Dumbo
Whats lft .
What was the yield like .
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
The way they make light weight adhesives is to remove the sand and replace with a lighter weight aggregate. I am sure it is a bit more complex than that, but that is the general method. So for example a 15Kg light weight adhesive and a 20Kg 'heavy' adhesive will have the same volume and hence the same coverage. da da!
Dumbo
So you have never seen a bag of magix then it's nowhere near the size of a 20k standard .
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
I have checked with BAL (Supercover) and they confirmed that when mixed the volumes on Supercover and a 'standard' 20Kg bag are the same. I also rang Tilemaster and their explanation was very strange. They said the mixed volume of Magix is similar, but slightly less than a 20Kg 'standard' bag, but it goes the same because of the glass beads. I struggle to see how this works. If the mixed volume is less and your trowel is the same then you will spread the same volume per m2, so it should not spread as far. OK, if the adhesive is super smooth you will perhaps waste less, but surely not by a significant amount. Perhaps that is why they call it Magic.
Reply to Light weight adhesives in the Tiling Standards area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
5K
Tiling Standards
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
