Discuss Limestone floor advice in the UK Tiling Forum area at TilersForums.com.
Time's Ran Out
Cameron - The only difference I find with Limestone is - Work as clean as possible.
When the tiles arrive they should be in a crate and stacked on edge.
Using clean hands and the edges of the tiles lift each one onto a flat surface (can do 4/5 at once), lightly brush off the dust with a soft painters dusting brush and seal,(we use a medium roller but with a drag action).
Do not wet, get finger marks or dirt onto the sealant/tile.
Then stack back on edge with spacer between tiles to allow air circulation to aid drying. They should be dry in 15 minutes for a second coat, but do not allow any sealant to lie/run on the surface.
Ditra could be used if you have UFH and the screed has the likelihood of cracking and a good adhesive will be White flexible and cement based.
After that it's good luck and enjoy.
Thanks for that John.
Couple of things regarding the type of roller you use ?
i generally use a gloss sponge roller on the trav, what do you use ?
I havent hand any comebacks with the trav so I assume its ok ?
As I dont have UFH, is ditra no necessary at all ? I hear of people putting it down religiously due to the expense of materials these days and the dreaded "COMEBACK" ! cheers again
Topshop
Don't let the sealer dry on the surface of any stone tile. Apply the penetrating sealer with a paint pad - let sink in - remove excess with a rag before it dries - re-apply if needed. You should never let your sealer be a topical or you will then see the fingerprints, footprints, and the tile will get sticky. Don't use a topical anything with any stone - that is unless you like plastic looking stone.
Reply to Limestone floor advice in the UK Tiling Forum area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
We're quoting to rip up and replace a tiled floor with Limestone tiles. I'm looking for advice...
Tilers Forums on FB
