Discuss limestone floor cleaned before and after in the UK Tiling Forum area at TilersForums.com.
Spud
I taped plastic protection all around the walls, architrave and skirtings up to 1m high using low tack masking tape as i used an floor buffing machine , then i used a degreasing cleaner, i wont mention brand names as most companies sell a generic degreasing cleaner ,this was mopped on to the floor and then i used a white 15inch white scouring pad on the buffing machine and then hoovered off the excess dirty water with a wet and dry hoover , the floor was allowed to dry out thoroughly and then the joints were lightly sanded with 120 grit sand paper which brought the grout up to its original colour ,the next step is to reapply new impregnating sealer, i chose Fila mp90 for this (other brands are available ) and sealed all the tiles and joints, this was repeated 3 times and the floor was finished using a clear paste wax which was buffed with a soft brush on the buffing machine
hope this helps
Gary
wetdec
Your right Gary m8 the stone is called Leonara and it was 15/16 years ago
Ive got a 15" one that folds in half (ye ye) ...........brilliant as its not standard size it gets closer into corners and stuff
There is a lot of good stone out there from this period that would should be cleaned in the last 5 years. The stone from back then will last the test as the veins from the quarries were good and fresh, wish i could say the same now a lot of the travertines today are not the best quallity unfortunately...................
:thumbsup:
Reply to limestone floor cleaned before and after in the UK Tiling Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
