Discuss Limestone Flooring in the British & UK Tiling Forum area at TilersForums.com.
Hi all
I am a newbie and am about to quote to lay some limestone floors (hallway and bathroom). Customer has tiles already, although I haven't seen them yet.
Anything I need to think about? I have read about how easily limestone is marked on the forum and wondered if I should seal it all before starting? Are there different grades of limestone as I am a little concerned it may be too soft for a hallway with traffic.
Any advice welcomed.
diamondtiling
If the customer has already bought the stone then is it to late to change it? Most natural stone is fine in a hallway, some very cheap travertine does the job so long as they are skimmed on the back to fill any holes.
Test piece a tile to see if it stains, if it does then they need cleaning and sealing prior to fixing and that needs to be reflected in your price. What name is the limestone because there are loads of different ones.
:thumbsup:
Time's Ran Out
This is a white limestone hallway we did a while back.
Some limestones are like blotting paper and even touching the surface with your hands will stain. Dust the surface with a soft brush and impregnate/seal surface as you carefully unload the tiles from the crate. Stack individually with an airflow to dry. Allow for a white adhesive and check the type of substrate ref decoupling. Then have fun.:smilewinkgrin:
wetdec
Hi Steve
Bit of a you help us we help you situation m8
If you get the name of the limestone, thickness, size and substrate we can more or less help you through the job (from a distance of course).
We are are handling this stuff daily and are always eager to see people do the fix correctly. Just need those 4 questions answered to get going m8
:thumbsup:
Thanks all
The limestone for the hall is from Manderine Stone and it is Marfil Honed 600 x 400 x 20, the limestone for the bathrooms is once again the same Marfil but polished and 610 x 305 x 10.
The honed stuff says it is suitable for high traffic. Anyone used this before?
Many thanks for all the useful advice.
Steve
wetdec
Thanks all
The limestone for the hall is from Manderine Stone and it is Marfil Honed 600 x 400 x 20, Tough stuff m8 shouldnt need sealing b4 you start go gentle with it is very hard so chips and can break along the veins. White flexible adhesive would be favourite I would think
The limestone for the bathrooms is once again the same Marfil but polished and 610 x 305 x 10. Mandarin are known to mesh their 10mm mafil so will take a little longer to go off once on the wall. Same adhesive as floor and again I would seal after. Check if its beveled as might look better with a 3mm spacer.
Oh yes, the hallway is concrete and the two bathrooms are floorboards so I guess I have to ply line them and then hardibacker?
UFH ?? if not straight onto concrete providing its well cured and in a good state of repair. Overboard with 10mm poly no advantage to using hbacker once over ply'd will need a uncoupling membrane tho over the ply.
The honed stuff says it is suitable for high traffic. Anyone used this before? Easy one of the best to be having a start with.
Steve
Steve :thumbsup:
Reply to Limestone Flooring in the British & UK Tiling Forum area at TilersForums.com
We're quoting to rip up and replace a tiled floor with Limestone tiles. I'm looking for advice...
We have just laid an outdoor patio and path using black limestone (now wishing I’d perhaps...
Sandhurst in Berkshire
Limestone Flooring
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
