Discuss Limestone tiled shower - Plan in the UK Tiling Forum area at TilersForums.com.
DRichards
Hi all,
Moneysaving heads up - You might know of this already - We used Tesco vouchers exchanged for Topps Tiles vouchers. LINK REMOVED,
Loads of great advice on this forum, I've searched & collected bits together, but it might not be a solid plan. Please let me know if you think I've missed anything.
I have all the time in the world to do this right. Watching the pennies but not skimping on what's needed. (Buy cheap - pay twice!:smilewinkgrin:)
Substrate
- new, standard plasterboard so will prepare with BAL WP1 tanking kit -
seal p'board with acrylic primer
Apply tanking coating
Apply tape to all joints
Apply tanking coating on top of tape
Limestone tiles
(600x400 mm) - no further cutting required
Sealed before tiling with Aquamix Sealer's Choice Gold. Can't get hold of the manufacturer's opinion of rear seal affecting adhesive strength!
Front, Rear and edges - 2 coats
24 hours between coats
Tiling
BAL rapidset flexible adhesive - (10mm notched trowel okay or would 6mm be better?)
fit bottom row first, leave to set for 24hrs
then complete tiling, clean & leave dry for 24-48hrs
Apply sealant to tile front and edges in place, Leave dry for 24hrs
Grout
BAL Microflex white wall grout - 2mm gap (does 2mm grouting look alright with a 600x400 tile, or would 3mm be better?)
Clean tile surface, leave dry, Final sealant coat to cover tile and grout. Leave for 2 weeks to dry out properly before use.
Thanks for your help!
Dan
:vanish:
Reply to Limestone tiled shower - Plan in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi, I did a limestone floor for a customer which I washed and sealed, then grouted 24 hours...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
