Discuss Lining up? in the British & UK Tiling Forum area at TilersForums.com.
Matthew77
If you find that the tiles are going out by a few mm then you can usually make this up around a door lining as you won't notice it in the width of the door. No good if you have tiled from each side of door lining and are going to meet up in the middle, in which case you'll have to open up your joints between each tile a little bit.
Find out how much you are out by & then divide that up by how many tiles you have left in the course...if that makes any sense
Reply to Lining up? in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Lining up?
Tags
usa
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
