Discuss lithofin cement away vrs KF cement residue remover in the Canada Tile Advice area at TilersForums.com.
Iam wondering if anyone has used lithofin cement away on porcelain tiles indoors?
I only ask as Iam in need of a strong cleaner for removing grey grout haze from black porcelain tile(not polished). It was recommended for me to buy KF cement residue remover but I cant find it locally but one tile merchant does stock cement away. They said the only difference was fues so am thinking it will be fine as long as well ventilated ?
I did try HG cement grout film remover but it hasn't been very effective. Any info is much appreciated.
Protilers
forget all that and get Universeal Cement Away dilute it 3-1 and apply......agitate it with a deck brush every 5 mins or so......then neauturalise the floor with Universeal Extreme Clean.
if that dont get it clean nothing will!......and you can contact Universeal direct for a next day delivery (maybe not is Scotland!) I am not sure as I dont work for them......0844 248 0581.....tell them Pro-Tilers sent you!!
hehehhehehehee
Yeah I have never used a strong acid cleaner but did read as you mention they dont react well with things like aluminum trim. Possibly a stupid question but whats the best method of using such a cleaner bearing in mind contact with metal? Just dilute with water in a bucket and use a sponge to clean avoiding contact with trim, then buff of and was thinking of washing down after with a normal cleaner.
Again thanks
Reply to lithofin cement away vrs KF cement residue remover in the Canada Tile Advice area at TilersForums.com
Hi Gents, In need of much advice as possible. I've recently just finished tiling 4 walls and...
6K
Hi we have tiled the bathroom with slate porcelain tiles and grouted using a ready mix glitter...
White Room
Just laid 30m limestone. All sealed with stain stop 3 days prior to laying. went down well and...
K
Please help - I know nothing about paving/tiling....!! We have just had some sandstone paving...
9K
Good morning/afternoon/evening all! im currently in the middle of converting one of our spare...
Tilers Forums on FB
