Discuss lock boy (Loch Boy) in the UK Tiling Forum area at TilersForums.com.
just wondering how many of you still use a lock boy for your getting a hole in tiles for pipes...ie...shower?
Dave or Grumps could you set this up as a poll please...you know me Russ i dont know how....ke:lol:
Used one this week to cut 6 holes out of really thick marble tiles, the holes were all really close together. did the job no probs. They still have there uses, unlike drills they don't wear out. With a little practice you can put a hole through a tile in about a minute. I'm not saying they are better than drills as I use a variety of drill bits for different types of tiles. What I am suggesting is that you don't have to spend a fortune on fancy tools if you know what what you are doing. A good tiler usually keeps their tools for years if they are looked after properly.
thanks for that, not tiling till monday so ill let you know next weekDon't tighten the clamp too tight or to slack, you want it enough so that when you tap the centre of the hole inside the clamp with the correct hammer, you won't be able to feel the vibration on the other side of the tile.
You want to start off with very very light taps right in the centre of the hole in the same place, on ceramics or porcelain-glazed tiles you'll start to break through the surface in time, on marble you'll start to see a small indentation pretty quickly.
Once you've started to chip away, keep tapping lightly in the centre, make the indentation bigger. As you get deeper you can hammer around the small indentation, but don't go near the edge of the hole in the clamp until you have worked your way right through the thickness of the tile in the centre.
Once you've created a small enough hole to see light through, you can start to move away from the centre towards the edge of the clamp hole.
The aim is to chip away and not actuall hammer the tile. So you're just using the point on the hammer tip to gouge a hole into the tile. You can neaten it up afterwards with the hammer around the edge, but some prefer using your tile nippers at that stage to creat square holes or large neat round holes.
Let us know how you get on.
Reply to lock boy (Loch Boy) in the UK Tiling Forum area at TilersForums.com
