Discuss Looking for advice in the Australia Tiling Forum area at TilersForums.com.
White Room
I've got a bathroom to do for a repeat customer in an old house. The first floor is a lime ash sreed over reed, it's out of level and weight is an issue. The client wants the floor tiling, would dirtra or something else be suitable for the floor? As the floor bounces a little. Any recommendations
Russ
I take you mean a screed over reed, the only reeds I know of are on walls....
Russell brown
yes a screed over reed. Basically the floor joist downstairs are exposed with no void between them and the floor. Reeds were laid over the joists and a lime and ash screed laid on top and a lime plaster underneath between the joists. Hopefully someone can tell me if it's possible.
thanks Russ
Andy Allen
1,318
Gloucester
Morning Russell. .....The most flexible adhesive I've found is bal single part fast flex.
I've no idea what type of floor your talking about, I've never seen one before. ....However 3 excellent experienced tilers are advising not to touch it and you would be well advised to listen to there advice. .:thumbsup:
Russell brown
I've been on the phone all day with various technical departments, Webber don't make anything suitable to use straight onto a lime substrate. Mapie are getting back to me, ardex reckon arditex NA will be suitable if primed with p51 primer and dural say the there matting will work as long as there's no more than 5mm deflection in the centre of a 3m straight edge when held against the floor. I haven't got all the information I'm happy with and im still not sure wether it's worth doing, but I'll continue to look into it as a learning curve as I've seen a few of these floors around here.
thanks for everyone's input so far it's all being taken on board.
Russ
White Room
The trouble also is the strength of lime mortar/substrate, by the sound off it the property is very old so is the lime and it is'nt a strong substrate and starts to break down over years.
Depending on what NHL strength that was used, the standard wall hydrolic lime used 3.5 NHL and goes upto 7.5 NHL which would be almost the tensile strength of concrete which I doubt was used.
Reply to Looking for advice in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Hi Thanks to all who provided advice on my bathroom project 3 years ago, tiling both the...
swanman
Hi all. I have recently been to look at a floor tiling job, where somebody has fitted a...
mbcmultitrade
Will try to keep this as short as possible.... Had a very heated discussion with a customer the...
charlie1
Looking for advice
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
