Discuss Looking for some expert advice in the Canada Tile Advice area at TilersForums.com.
Boggs
1,118
Uk
Beat me to it @Boggs ;)
Soz :)
[automerge]1588877588[/automerge]
Yes joists are under the chipboards panels
First thing to do is check for deflection in the floor, simple way is to brim a glass with water, put it on the floor and jump up and down. If the water splashes out then the floor will need some strengthening with extra joists or noggings.
If it passes then overboard with 6mm Hardie backer, installed to manufacturers instructions and tile on top using a good quality adhesive.
You should be good to go then.
Reply to Looking for some expert advice in the Canada Tile Advice area at TilersForums.com
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
Hi Everyone. I'm after some advice with regard large format Tiles with water fed underfloor...
Tiberiu Curelaru
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Tilers Forums on FB
