Tiling Tool Suppliers
Discuss Loose wire UFH clips in the For-sale and Wanted area at TilersForums.com.
Q
Qwerty
After a long search on the internet I managed to source some really well made loose wire underfloor heating wire clips. These are in fact galvanised steel banding with clips built in. I had to import a whole load for a few ufh projects I have and they have been an absolute God send! I also purchased the matching self adhesive foam tape which is designed to be used with the banding.
Here are the specs-
Screed Fix fixing strip
Generally installed and the heating cable secured under the fixing tabs to hold it securely in position when the floor screed or self levelling is poured. The fixing centres that can be achieved at 3.5 cm pitch are: 3.5 cm, 7 cm, 10.5 cm, 14 cm and 17.5 cm.
Fix to slab, screed or insulation boards using either the dedicated self adhesive tape or by screwing down.
Self adhesive tape for Screed Fix Comprises a 100% partially modified highly cross linked, high shear acrylic adhesive, which is coated on to a high density polyolefin foam substrate.
The unique combination results in a product which has great adhesive strength and exceptionally high level of initial tack.
The tape is completely inert, free from solvents and will not out-gas or bleed plasticisers.
Both items are 12mm wide x 1mm thick x 10m long
Prices (per roll and includes free delivery)
Screed Fix fixing strip £12
Self adhesive tape £6
PM me if interested :)
Reply to Loose wire UFH clips in the For-sale and Wanted area at TilersForums.com
gamer1
I am sure someone will know a good practice solution. We started a wetroom last year and then...
23K
Deleted member 57709
Hi, I have a tiler turning up next week to tile my refurbished bathroom. He always uses Rocatex...
For Sale
For-sale and Wanted
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
