Discuss Low screed - advice please? in the Canada Tile Advice area at TilersForums.com.
amsie
Hi all, Tiler by trade.
Having a home extension done and a plasterer friend of mine kindly offered to do my screed for me. However, he has somehow managed to do it 20mm out of level. Starting off 20mm too low from the mark sloping over 3.5m to 40mm too low. Room length is 5m. Im gobsmacked to say the least and I could have done a better job myself!!!! However, its obviously left me with a problem screed.
Some of the options put to me have been take it all out and start again or SBR slurry/SBR screed with fibres into it, either grinding the floor or scabbling it. I've also been told this might not work???.
SLC by my calculation would prove very expensive.
I would really appreciate some advice and options please. Id rather not take the whole lot up unless it really has to come out.
Thanks in advance
Paul
Ajax123
1,213
Lincolnshire
If you could squeeze it up to minimum 25mm you could use a sureflo bagged screed bonded. You would need to SBR and sand broadcast over the existing screed to provide a good mechanical key. I suspect it would be considerably cheaper than using a self levelling compound.
It is too thin to put in a traditional screed even with fibres in.
Sureflo is GYPSOL self compacting anhydrite screed in bags available from CCF. You can mix it and install it yourself. If you need a contact for who to speak to send me a private message and I will be happy to help.
otherwise you are pretty much left with self levelling compounds at the depth in question.
Reply to Low screed - advice please? in the Canada Tile Advice area at TilersForums.com
gamer1
Dear Tilers, my husband has done a lot of tiling, but would really like your advice please. He...
Hi, My tiler has just left and apart from him chatting to me about his life story for majority...
Hi Everyone, My tiling job has come to a standstill, please help. The concrete floor was...
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
