Discuss Main Earth and Gas Bond Electrical Advice in the Electrical Advice area at TilersForums.com.
Main Earth and Gas Bond Discussion ThreadMain Earth and Gas Bond Electrical Advice
Folks need advice. House I am working on. TT earthing. The rod is closer to the gas pipe/meter box than the Consumer Unit. I wondered why I could find no bonding conductor in the CU. It appears someone took the Main Earth 16mm cable from the earth rod to the gas pipe and then onto the Consumer Unit. The cable is not broken and continuous. II can't see this being correct but can't establish where in Regs it's not compliant. Maybe I am too fussy as I like to see bonding conductor's on the MET not going hunting for them. Am I right, if so where in Regs?
Main Earth and Gas Bond for the original thread on Electricians Forums
Reply to Main Earth and Gas Bond Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
