Discuss Making wall Good advice in the UK Tiling Forum area at TilersForums.com.
Davesax
I'm tiling 4 bathroom walls , one of which ( not the wet wall ) is stud /plasterboard with insulation.
The other 3 walls are goo to go but where tiles have been removed there are a couple of fist size holes . I want to avoid reboarding just for these and wondered what the best way to make this good is . is there a trick to skim with rapid set and get it to stay flush without losing it between the studs?
Dave
Diamond Pool Finishers
this is simple , get a piece of plasterboard, cut it to fit inside of the hole with some juggling, then put two small holes in the centre then thread string throught these and knot the string on the back-side then put plaster-board adisive around the edge , then carefully put into the hole holding the string, then pull string towards you and the board will stick to the inside of the hole !! leave this to set ,then cut string and fill flush with backing plaster job done!!
diamondtiling
I was going to put the same answer Dave but you explained it better than me mate.
:thumbsup:
Reply to Making wall Good advice in the UK Tiling Forum area at TilersForums.com
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
Hi, Absolute newby here in terms of tiling. Having been doing lots of research and I think I`m...
Hi everyone, I'm getting towards the end of a major renovation that has taken 4+ years so don't...
