Discuss Mapei Grout Scratches in the UK Tiling Forum area at TilersForums.com.
Has anybody out there had an issue with Mapei Ultrcolour Plus Grout scratching the surface of ceramic tiles?
Just fixed a small area of high gloss black ceramics and grouted as usual using Mapei Anthracite grout. When I polished of the minimal residue almost all of the tiles had fine surface scratches, only really visible when the lights directly above them were turned on. I checked each tile before fixing and they were fine so it is obviously the grouting that has done it. I have fixed loads of the same tile but this is the first time I've used Anthracite grout on them, on floors yes but a first on walls and on gloss black.
Anyone had the same?
Anyone any possible remedies apart from taking them all off and starting again but with a different grout?
Spooner
First time (and last) that I've used that type of grout with glossy tiles, the client got it along with the tiles. Like I said, I've not had a problem with any other grout like this. Not the end of the world, a couple of hours to knock them off and start again. Nice coffee and cake makes it worth a revisit.
U
user123
On sensitive surfaces try using kera colour FF.
Hm, interesting, does that mean it's a finer grout than ultracolour then? Could be interesting for me ... does it come in the same colour range? Just googled it and it mentions fugolastic - have you ever used that, does that make it creamier still?
DHTiling
Wide joint grouts are a coarse grain of sand.. so yes the finer the grout the better for glass or polished surfaces.. FF will go to a 6mm joint.
And same colour pallet as Ultra colour
Just been reading the technical spec on the Ultra Colour Plus and it says its suitable for all ceramic and glass tiles. Hmm. Will be chatting to the rep on Monday and see what he reckons.
I have used Fugolastic and GT1 as additives for areas where there has been a risk of too much movement for standard polymer mod grout. Slightly different in that Fugo is a water replacement and the GT1 is a supplement. No probs either way.
DHTiling
As in it will bond to them..:lol:.. surface scratches is the grout grains..
Reply to Mapei Grout Scratches in the UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
Tyne Valley, Northumberland
Business Name
Tyne Valley Tiling Limited
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
