Rich
Hello all, Thought Id put some info up on the Mapei range of powder adhesives. Might help a few people out.
Kerabond T
Cement based adhesive with no vertical slip, for fixing all types of ceramic tiles.
Where to use : Fixing all types of ceramic tiles and mosaics to solid, dry internal and external walls and floors on cementitious or gypsum substrates (when primed with primer G). When mixed with Isolastic as a substitute for water the performance characteristics improve, satisfying class C2T-S1 with 50% Isolastic and C2T-S2 with 100% Isolastic.
Adesilex P9
Polymer modified and enhanced adhesive for fixing ceramics, porcelain and mosaics of every type, with no vertical slip.
Where to use: Interior/exterior floor and wall bonding of ceramic tiles and mosaics on conventional walls with cementitious renders and screeds and gypsum walls, (when primed with primer G) painted interior walls, existing marble or terrazzo floors and suitably cured concrete structures. Also suitable for use in swimming pools.
Adesilex P10
White, high performance cementitious adhesive with no vertical slip and extended open time for glass, ceramic and marble mosaic coverings.
Where to use: Interior and exterior floors, walls and swimming pools (mixede with Isolastic diluted 1:1 with water) bonding of glass, ceramic and marble mosaics on paper or netting on cementitious renders, cememtitious screeds, anhydrite screeds and gypsum walls (specifically primed before hand), interior walls in foamed concrete blocks, gypsum board, underfloor heating systems, suitably cured concrete structures and painted interior walls (as long as paint is well anchored).
Keraflex
Cementitious adhesive, with no vertical slip and extended open time, for ceramic tiles and stone materials.
Where to use: Interior/exterior wall and floor bonding of all types of ceramic tiles and ceramic mosaics, stone material (as long as moisture stable) on cementitious renders, cementitious screeds, anhydrite screeds and gypsum walls (as long as they are primed beforehand with primer G), interior walls in foamed concrete blocks, gypsum board, underfloor heating (max. tile size 900cm2), painted interior walls, paint must be well anchored, existing marble, terrazzo & ceramic tile floors, bonding in basins & swimming pools.
Keraflex maxi
High performance single part flexible adhesive with no vertical slip, extended open time and inbuilt flexibility, for ceramic tiles, porcelain and stone materials.
Where to use: Interior/exteriorwall and floor tiling. Bonding all types of ceramic and porcelain tiles, mosaics and natural stone on conventional wall substrates, render, plaster, plasterboard, marine ply and other board types. Floor substrates include cement screed, anhydrite screed, concrete and marine ply. Particualy suitable for lage sized porcelain tiles and moisture stable stone materials and underfloor/undertile heating.
Bed thickness 3-15mm.
N.B Gypusum Plaster & Anhydrite must be primed.
Mapei Rapid-set
Cement based rapid setting adhesive for interior and exterior floor and wall installations of ceramic tiles and quarry tiles.
Where to use: Interior/exterior wall and floor tiling. Bonding all types of ceramic tiles, and quarry tiles onto conventional wall and floor substrates; render, plasterboard, cement, screed or gypsum (after priming with primer G) etc.
Mapeker
Fast setting adhesive for fixing all types of ceramic tiles and mosaics.
Where to use:Fixing all types of ceramic, porcelain and mosaics to solid dry, internal and external walls and floors on cementitious of gypsum (after priming with primer G) substrates. The cured adhesive is frost proof and water resistant and can be used for showers, balconies and patios.
Adesilex P4
High performance pourable rapid setting full contact cementitious adhesive for ceramic tiles and stone materials.
Where to use: Pourable adhesive for interior/exterior floor bonding of all types of medium and large size ceramic tiles, stone materials in enviroments subject to heavy traffic on: existing floors, cementitious screeds, underfloor heating systems and gypsum (after priming). Can also be used as an internal and external levelling compound.
Keraquick
Fast setting polymer modified fleible adhesive for fixing all types of ceramic, porcelain and glass tiles, mosaics & non-moisture sensitive natural stone.
Where to use: Fixing all kinds of ceramic, porcelain & glass tiles, mosaics and natural stone to solid dry internal and external walls and floors, on cementitious or gypsum (after priming with primer g) substrates. Suitable for underfloor heating, swimming pools and wet areas. Mix with Laytex Plus for increased deformability (S2) for use onto wooden floors.
Granirapid
Two component rapid set S1 adhesive for stone conglomerate marble & resin bonded tiles.
Where to use: Particualy suitable for the installation of stone material which require a rapid drying adhesive. Siutable for bonding floors subject to heave traffic. Due to extaordinary bonding and fast setting properties it is particularly suitable for rapid re-tiling jobs and flooring that has to be accessed within a short time e.g. hospitals.
Elastorapid
Two component flexible rapid set S2 adhesive for stone, conglmerate marble & resin bonded tiles.
Where to use: Particularly suitabl foe the installation of ceramic tiles and large stone material slabs on exteriors and in swimming pools. For the installation of floors subject to heavy loads and for bonding ceramic tiles on deformable substrates (plywood, old wooden beam floors etc.) and gypsum (after priming). The longer open time makes Elastorapid particularly suitable for summer use where immediate service is required
Ultraflex Mono
One component, high performance,slip resistant with extended open time highly flexible class S2 (EN12002) adhesive with very high yield.
Where to use: For bonding all sizes of ceramic tiles, mosaics and stone material (if dimensionsally stable) on traditional internal and external floors and walls with cementitious render, cement and anhydrite screeds, plaster walls (after application of suitable primer), internal cellular concrete walls. plasterboard, painted internal walls (if paint is well bonded), old marble, terrazzo and ceramic floors and waterproofing substrates with Mapei waterproofing and anti-fracture membrane.
Ultraflex Quick
One component, high performance, highly flexible class S2 (EN 12002), slip resistant, fast setting adhesive with very high yield.
Where to use: For bonding all sizes of ceramic, mosaic and stone material (if dimensionally stable) on traditional internal and external floors and walls with cementitious render, cement and anhydrite screeds, plaster walls (after application of suitable primer), internal cellular concrete walls, plasterboard , painted internal walls (if paint is well bonded), old marble, terrazzo and ceramic floors and waterproofing substrates with Mapei waterproofing and anti-fracture membrane.
Kerabond T
Adesilex P9
Adesilex P10
Keraflex
Keraflex maxi
Mapei Rapid-set
Mapeker
Adesilex P4
Keraquick
Granirapid
Elastorapid
Ultraflex Mono
Ultraflex Quick
