Discuss Mapei Primer G on top of SBR (prior to Mapegum tanking) in the British & UK Tiling Forum area at TilersForums.com.
Q
Qwerty
If it says use primer G, then why haven't you used it..?....the sbr should be fine but worth checking with mapei to see if the mapegum will adhere to it.
I havent done it yet, hence why I have posted the question. Just wasnt sure if the Mapegum had to be on top of Primer G or if it would work with SBR. Will ask Mapei
L
lalit
If I have already primed all of the plastered walls with SBR (Everbuild from Tradetiler), is it advisable to apply Mapei Primer G on top of this prior to Mapegum, or do I just tank straight on top of the SBR?????
Thanks - Geoff
Hi Geoff, I am in the similar situation, What did you do in the end?
Lalit
Q
Qwerty
Wow! This post is 4 yrs old now! (Posted when I was a wee novice).
Yes, you will be fine with SBR from memory, but do use primer G if you can which is what I did in the end. Give Mapei tech support a call to double check if anything has changed though!
I only posted the question back then as I had a fetish for the smell of SBR over primer G !!!
Reply to Mapei Primer G on top of SBR (prior to Mapegum tanking) in the British & UK Tiling Forum area at TilersForums.com
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
