Discuss Mapei tanking tape question (another) in the UK Tiling Forum area at TilersForums.com.
N
nigelsmith
I'm a little confused about how to apply the tanking tape!
1. if both sides of the tape are to be behind tiles, ie in a vertical corner, do I still need to remove the scrim from the edge?
2. should the tape be applied scrim side to the wall, or rubber side to the wall?
3. do I need to peel the scrim off the tape after application?
Probably silly questions but I can't work it out from the leaflet.
Many thanks for any help!
DHTiling
tommyzooom
1,083
Ireland
The scrim side goes to the wall, and the liquid is designed to seep through the scrim part, which also has a second coat applied on top . This is to reinforce the corner, and when the scrim is soaked in liquid, it too becomes waterproof.
You should not cut off the scrim!!!
Reply to Mapei tanking tape question (another) in the UK Tiling Forum area at TilersForums.com
Hi, Absolute newby here in terms of tiling. Having been doing lots of research and I think I`m...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi folks, I have been doing a lot of research as to which is the best tanking product to use on...
8K
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
