Discuss Mapei Ultraplan Eco leveling compound. Can you use it with UFH? in the Australia Tiling Forum area at TilersForums.com.
Stef
As far as I remember, I didn't think it was ok for ufh though I may be wrong. I use Mapei Renovation screed for such jobs. If it is ok I might start using it cos its about a fiver a bag cheaper than Reno which is a significant saving on a pallet.
I meant to phone Mapei tech today to double check for the Eco & forgot.
I ended up using 2 bags of Eco as the floor is way out & that's before I install the heat mat.
Will Phone tech in the morning & check, I usually use renovation screed but if they say it's ok then i know what I'm using..
Must say though this floor I'm doing is over a screed & is not a wooden floor, if it's wood then I'm certain you must use renovation screed..
Q
Qwerty
Never used it myself as always use Ultraplan Renovation Screed. Here are the tech specs....
http://www.mapei.com/public/GB/products/513_Ultraplan Eco_UK.PDF
My understanding from this is that it can be used over UFH within a screed, but not worded the same as the renovation screed which says "suitable for use with UFH"
Deffo a call to mapei tech!!! [emoji1]
Stef
I forgot to phone technical, I levelled out the floor with Eco then fitted the heat mat & used renovation screed to cover the wires.
If you are over timber then you will need to use renovation screed as Eco doesn't have any flex in it, it's only for over a screed.
The floor I'm fitting the mat to is a small utility room over screed.
Q
Qwerty
I used Ultraplan Eco this morning on part of an old screed to level it ready for next week. This stuff is great to use. Mixes really well and so smooth to the point I had to double check that I hadn't used too much water as I'm used to Renovation screed consistency. It poured & levelled perfectly and has set nicely. I'm going to be using this on all solid (non heated) floors from now on.
Left the remainder in the gorilla tub to set and knock out and it's rock solid already!
Reply to Mapei Ultraplan Eco leveling compound. Can you use it with UFH? in the Australia Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
