Discuss Marble Fireplace On New Plaster in the UK Tiling Forum area at TilersForums.com.
E
EViS
We are replacing an old fireplace surround for a new marble one. The old surround has been ripped out and the wall re-plastered (hardwall and multi-finish) today. Do you guys reckon we would be safe to install the new fireplace on Friday (i.e. the plaster would have only had 2 days to dry) using a stone tile adhesive?
The customer doesn't want to wait 1 month but will no doubt call us back should the fireplace surround fall down. Seeing as we're not tiling an entire wall, I am leaning to the side that the plaster will support the fireplace surround, especially seeing as it will be supported vertically on the ground by the hearth.
What do you guys reckon?
Concrete guy
This isn't quite the same as considering sq/m tiling weights as (I'm assuming) the fireplace is fundamentally supported by the floor.
The bond to the wall it therefore not structural but just stability.
As long as you're comfortable that the plaster is cured enough to get a permanent bond then fine. 2 days is a bit tight though, unless the plaster is particularly thin. I'd want a few more days than that minimum.
Del W
1,113
Canterbury
Whats the total thickness ? Id allow 1 day per mm drying time.
That said,with all the hot weather in my part of the world at the moment,it could dry a lot quicker.
Reply to Marble Fireplace On New Plaster in the UK Tiling Forum area at TilersForums.com
  • Sticky
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Hi Everyone - I'm new here, please be gentle. I am just about to start to tile a new extension...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
