Discuss Marble impregnator in the British & UK Tiling Forum area at TilersForums.com.
TilingLogistics
Different marbles have different surface tension (the final finish on the marble). Normally with a highly polished marble it will be more difficult to impregnate with the sealer. Different make sealers vary tremendously but in general they all need a carrier to take the sealer below the surface and that can either be a solvent, water or combination. As a rule of thumb polished marble accepts solvent or combination based sealers the best. However, the best way is to carry out a test on a spare piece with a couple of different sealers until you are satisfied with the result. Be patient when applying and most importantly follow the application directions. Good Luck:thumbsup:
Kev
DHTiling
Sorry to hear of this dilemma..........HG do an impregnator for marble...also lithofin stainstop is good as well.......but as mentioned mixing sealers doesn't work.....
I would contact HG and see what they recommend to use to remedy this problem.......
You can phone them on 01603 714341
or you can email them direct >>>HERE<<<
good luck and let us know how it goes........:thumbsup:
Reply to Marble impregnator in the British & UK Tiling Forum area at TilersForums.com
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
Hi all, I was hoping to get some input/help on this situation. Background: We had 12 x 24"...
Marble impregnator
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
