Discuss Marble Tiles on Solid Plastered Wall in the America Tile Forum / Advice Board area at TilersForums.com.
Hello,
Just about to embark on an extension and the first job is to move the bathroom into what was part of the old living room.
The walls are solid blockwork with a plaster finish (and wallpaper).
I would imagine marble would be too heavy to fix directly to the plastered wall so I was wondering what would be the best way of preparing the walls such that I lose the minimum of space in the room please?
The obvious thing that comes to mind is battening it out and using a 12mm cement tile backer board. This will lose a good 40mm by the time the tiles are on though which is not ideal as space is a little tight.
I'm wondering, however, that if the walls are flat enough, is it possible to use 6mm board and adhesive directly to the wall with plenty of screws to supplement the adhesive? Instinct tells me that's a bad idea but on the face of it it doesn't seem that different to screwing battens to the wall then screwing boards to them.
Alternatively, if all the plaster was removed, can you tile directly to blockwork or a sand and cement render?
Thanks!
Reply to Marble Tiles on Solid Plastered Wall in the America Tile Forum / Advice Board area at TilersForums.com
Budget renovation as I just bought the flat. Cavity brick walls, 1 external. Removed old tiles...
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
USA Tile Forum Popular
America Tile Advice Trending
London
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
