Discuss Marine ply please help in the UK Tiling Forum area at TilersForums.com.
richardkear
Totally confused now. Have recently pulled up tongue and groove flooring and replaced with 18mm marine ply to tile directly onto.
I also have one wall that I intend to tile on which will be 12mm marine ply. I have used this as I have to fix a concealed mixer riser rail and several other fitting to it. I also have a recessed shelf in this wall.
I posted a question ref tiling a window header which I boarded out in 12mm marine and asked why it was ply and could it be plasterboard.
Questions
1. Is the 18mm marine ply floor ok to tile onto
2. Do I now have to overboard the 12mm marine ply with plasterboard
3. Same question for the window header.
The marine ply wasn't cheap but I read elsewhere this was the way to go :(
Tony321
Hi Richard,
1)As long as Wooden Floors timber bases must be rigid. Is the marine ply directly over the joists if so i would put knoggings at the edge of the plywood. Seal rear and edges of timber, do not prime the surface, but clean off timber dust.
2)If you choose to tile over plywood you need to Seal rear and edges of timber, do not prime the surface you are tiling on, with an acrilic primer?
Also the plywood should not be butted up leave a 2mm gap for slight movement, also use a cement based flexable adhesive with a solid bed (in shower) it is always best to tank showers with a waterproof kit.
6mm Wedi board on top would be the best option if the buget allows.
But if done correct the ply will be fine.
Reply to Marine ply please help in the UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
Hi all I was hoping to get your opinions / thoughts on some work done in the kitchen by the...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
TF Group Please Join
