Marking darker tiles
Akhlaq147
Hi, I am wondering if anyone can help me.
When I need to cut a tile using a wet cutter, I draw the line(s) using a normal felt tip really. But the second I put it in front of a wet cutter, you can probably guess what happens. That line vanishes in a split second.
Is there a special pen or anything that I can use?
Please help, thanks!
As above. I use a pencil or biro, Make sure the line is as thin as can be to get a tight cut and cut on the relevant side of the line, not just down the middle.
:thumbsup:
Try the above from Trade Tiler
wouldn't be without my white pencil. Some simple things make life so much easier
I sometimes score the stone with the manual cutter as cj does above but i use a light coloured china marker from tradetiler..the wax leaves a mark along the edge of the score which doesnt get washed away.
I am very greatful for all your replies.
This china marker looks like just the thing I need, and tradetiler.com looks like a very useful website.
Thank you.
Another good trick is to mark both ends of the tile and then use masking tape as a line, then just cut down the tape - works a treat!
