PHG
Designed for shower and wetroom applications the Marmox Showerlay is pre-formed to create an effective water slope to the drain. It is a floor level panel that can easily be cut to fit the shower area or to produce an irregular or circular shower base. As with all Marmox products the Showerlay is ready to receive a tiled finish of the customer's choice. Made with a waterproof extruded polystyrene core and a double reinforced surface that is compatible with most tile adhesives. A thin stainless steel sheet has been built in to reinforce the waste outlet hole. The Marmox Showerlay is robust enough to allow mosaic tiles as small as 50mm to be laid on it without the risk of compression through point loading and is compatible with the Marmox / Dallmer shower drain.
Marmox Showerlay Formers - PHG Wetrooms
