Discuss Max silcone gap for bathtub in the Canada Tile Advice area at TilersForums.com.
Crumbs
hi guys, i need to silcone around my bathtub, its been recently tiled and ive noticed the gap is quite large in a few places. It sits back slightly from the lip so the full gap is around 6mm in a few spots, and 4-5mm in the rest.
If you put a spacer flat on the bath and push under the tile its about flush to 3mm but diagonally as they sit back furthur its more.:mad:
Will this be ok to fill with silcone, not sure the max joint width silcone should not exceed? cheers:D
Hi not sure what colour your tiles are? By matching the tile colour with the sealant the gap will less noticeable (use a good quality sanitary sealant like Mapei or BAL). The only problem is that you have to be really neat where the sealant meets the bath.
I would make sure the gap is completely dry and free from adhesive/grout. Add sealant, then spray with water with a little washing up liquid added. Then use a finishing tool and multi wipes to get a tidy seal.
Reply to Max silcone gap for bathtub in the Canada Tile Advice area at TilersForums.com
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
    • Dislike
Hi all, new to this forum so thank you in advance for reading my post. I'll try to be short and...
Jacko
Hi guys, after a bit of advice please. I am doing my first attempt at tiling, main walls pretty...
First post on this forum and unfortunately its not under good circumstances. We have built...
14K
Reggiethethird
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
